jQuery UI Widgets › Forums › TreeGrid › I’m not sure how to proceed with: TreeGrid. Help needed!
This topic contains 1 reply, has 2 voices, and was last updated by admin 6 months, 2 weeks ago.
How can I use Angular services to fetch hierarchical data for jqxTreeGrid?
To load hierarchical data and especially on demand, i suggest you to look at this code below as an approach:
import { Component, ViewChild } from '@angular/core'; import { jqxTreeGridModule, jqxTreeGridComponent } from 'jqwidgets-ng/jqxtreegrid'; @Component({ selector: 'app-root', imports: [jqxTreeGridModule], standalone: true, templateUrl: './app.component.html' }) export class AppComponent { @ViewChild('TreeGrid') treeGrid: jqxTreeGridComponent; generateTasks(rowsCounts?: number): any { let rowsCount = !rowsCounts ? 1 + Math.floor(Math.random() * 5) : rowsCounts; let data = new Array(); let generatekey = () => { let S4 = () => { return (((1 + Math.random()) * 0x10000) | 0).toString(16).substring(1); }; return (S4() + S4() + '-' + S4() + '-' + S4() + '-' + S4() + '-' + S4() + S4() + S4()); }; for (let i = 0; i < rowsCount; i++) { let row = {}; let tasks = ['Shopping', 'Housewares', 'Kitchen supplies', 'Groceries', 'Cleaning supplies', 'Office supplies', 'Remodeling', 'Paint bedroom', 'Paint wall', 'Fitness', 'Decorate living room', 'Fix lights', 'Fix front door', 'Clean kitchen']; let firstNames = [ 'Andrew', 'Nancy', 'Shelley', 'Regina', 'Yoshi', 'Antoni', 'Mayumi', 'Ian', 'Peter', 'Lars', 'Petra', 'Martin', 'Sven', 'Elio', 'Beate', 'Cheryl', 'Michael', 'Guylene' ]; let lastNames = [ 'Fuller', 'Davolio', 'Burke', 'Murphy', 'Nagase', 'Saavedra', 'Ohno', 'Devling', 'Wilson', 'Peterson', 'Winkler', 'Bein', 'Petersen', 'Rossi', 'Vileid', 'Saylor', 'Bjorn', 'Nodier' ]; row['id'] = generatekey(); row['firstname'] = firstNames[Math.floor(Math.random() * firstNames.length)]; row['lastname'] = lastNames[Math.floor(Math.random() * lastNames.length)]; row['name'] = row['firstname'] + ' ' + row['lastname']; let taskindex = Math.floor(Math.random() * tasks.length); row['task'] = tasks[taskindex]; row['duration'] = 1 + Math.floor(Math.random() * 10); data.push(row); } return data; }; getWidth(): any { if (document.body.offsetWidth < 850) { return '90%'; } return 850; } virtualModeCreateRecords = (expandedRecord, done): void => { //expandedrecord is equal to null when the is initially called, because there is still no record to be expanded. //prepare the data let source = { datatype: 'array', datafields: [ { name: 'id', type: 'string' }, { name: 'name', type: 'string' }, { name: 'duration', type: 'number' }, { name: 'task', type: 'number' } ], localdata: expandedRecord === null ? this.generateTasks(3000) : this.generateTasks(), id: 'id' }; let dataAdapter = new jqx.dataAdapter(source, { loadComplete: () => { done(dataAdapter.records); } }); dataAdapter.dataBind(); }; virtualModeRecordCreating(record): void { if (record.level == 2) { // by setting the record's leaf member to true, you will define the record as a leaf node. record.leaf = true; } }; columns: any[] = [ { text: 'Task', dataField: 'task', align: 'center', width: 200 }, { text: 'Person Name', dataField: 'name', cellsAlign: 'center', align: 'center', width: 200 }, { text: 'Duration', aggregates: ['sum'], dataField: 'duration', cellsAlign: 'center', align: 'center', cellsRenderer: (row, column, value) => { let hour = value > 1 ? ' hours' : ' hour'; return value + hour; } } ]; }The important things are virtualModeCreateRecords and virtualModeRecordCreating
Peter -
