jQuery UI Widgets › Forums › Scheduler › I’m checking whether I’m using: Scheduler correctly.
This topic contains 1 reply, has 2 voices, and was last updated by  admin 1 year ago.
  • jovanovic
    I want to display appointments from multiple resources in jqxScheduler’s timeline view. How can I structure the data for Angular?
    admin
    To display appointments from multiple resources in the jqxScheduler’s timeline view using Angular, you’ll need to structure the data properly so that it matches jqxScheduler’s expectations for resources, appointments, and time slots.
    Here’s a step-by-step guide on how you can achieve this:
    1. Install jqxScheduler and jqWidgets in Angular
    First, make sure you’ve installed jqWidgets in your Angular project. You can do this using npm:
    npm install jqwidgets-ng
    Then, import the necessary module into your Angular module:
    import { jqxSchedulerModule } from 'jqwidgets-ng/jqxscheduler';
    @NgModule({
      declarations: [ ... ],
      imports: [ jqxSchedulerModule, ... ],
      bootstrap: [AppComponent]
    export class AppModule { }
    2. Prepare the Data Structure
    To display appointments from multiple resources, you’ll need two main things:
    Resources: These represent the different resources in your timeline (e.g., rooms, employees, etc.).
    Appointments: These represent the scheduled events for each resource (e.g., meetings, bookings).
    Example Data Structure:
    Resources (This can be a list of resources such as rooms, staff, etc.)
    Appointments (Each appointment will be linked to a specific resource.)
    // Example resource data (can represent rooms, employees, etc.)
    resources = [
      { id: '1', name: 'Room 101' },
      { id: '2', name: 'Room 102' },
      { id: '3', name: 'Room 103' }
    // Example appointments data (linked to resources)
    appointments = [
        resourceId: '1',  // Linking to 'Room 101'
        subject: 'Meeting with John',
        start: '2025-10-10T09:00:00',
        end: '2025-10-10T10:00:00'
        resourceId: '2',  // Linking to 'Room 102'
        subject: 'Project Discussion',
        start: '2025-10-10T10:30:00',
        end: '2025-10-10T12:00:00'
        subject: 'Team Meeting',
        start: '2025-10-10T13:00:00',
        end: '2025-10-10T14:00:00'
        resourceId: '3',  // Linking to 'Room 103'
        subject: 'Client Presentation',
        start: '2025-10-10T14:30:00',
        end: '2025-10-10T16:00:00'
    3. Configure jqxScheduler
    In your component where the jqxScheduler will be displayed, you need to configure the scheduler to use the resources and appointments data properly.
    Here’s an example setup in your component:
    Component HTML (app.component.html)
    <jqxScheduler [resources]="resources"
                  [appointmentsDataField]="'appointments'"
                  [appointmentDataFields]="appointmentDataFields"
                  [timelineView]="true"
                  [date]="'2025-10-10'"
                  [width]="'100%'"
                  [height]="'600px'">
    </jqxScheduler>
    Component TypeScript (app.component.ts)
    import { Component } from '@angular/core';
    @Component({
      selector: 'app-root',
      templateUrl: './app.component.html',
      styleUrls: ['./app.component.css']
    export class AppComponent {
      resources = [
      appointments = [
      appointmentDataFields = {
        id: 'id', // Unique ID for the appointment
        resourceId: 'resourceId', // Resource ID that the appointment belongs to
        subject: 'subject', // The title of the appointment
        start: 'start', // Start time of the appointment
        end: 'end' // End time of the appointment
    4. jqxScheduler Timeline View Configuration
    To make sure the appointments appear in the timeline view, the following points should be set up:
    resources: Defines the resources that will be displayed on the timeline.
    appointmentsDataField: Tells the scheduler where the appointments data is located.
    appointmentDataFields: This specifies how each appointment is mapped to a data field in your appointments array (e.g., id, subject, start, end).
    timelineView: Set this to true to ensure that the scheduler is displayed in the timeline view.
    5. Styling and Customization
    You can further customize the look of your appointments and resources, for example by changing colors based on the type of appointment, adding labels, or adjusting the timeline’s appearance.
    ::ng-deep .jqx-scheduler-appointment {
      background-color: #007BFF;
      color: white;
    ::ng-deep .jqx-scheduler-resource-cell {
      background-color: #f0f0f0;
    Hope this helps.
    https://www.jqwidgets.com/
