jQuery UI Widgets › Forums › General Discussions › Navigation › Tree › How to interpret element in using the ensurevisible method
This topic contains 6 replies, has 2 voices, and was last updated by admin 6 months, 1 week ago.
I would appreciate some guidance on how to interpret the nature of ‘element’ in the sample script as:
$(‘#jqxTree’).jqxTree(‘ensureVisible’, element);
If the look at the record structure given in the sample html script, which is:
{ label: “Item 1”, expanded: true,
items:
{ label: “Item 1.1” },
{ label: “Item 1.2”, selected: true }
{ label: “Item 2” },
{ label: “Item 3” },
{ label: “Item 4”,
items:
{ label: “Item 4.1” },
{ label: “Item 4.2” }
{ label: “Item 5” },
{ label: “Item 6” },
{ label: “Item 7” }
];How exactly should I interpret ‘element’ in this context?
Any guidance will be really appreciated!
Many thanks,
Alastair
Hi Alastair,
ensureVisible works with indexes i.e you need to pass the element’s index – 1, 2, etc.
https://www.jqwidgets.com/Ok – thank you very much! The guidance is appreciated!
Alastair
Sorry, the previous was for jqxTabs. For jqxTree, you need to pass HTML Element. Example: https://jsfiddle.net/jqwidgets/VvB6g/
https://www.jqwidgets.com/I looked at the jsfiddle example – but I am none the wiser.
The xample I am trying to explore this issues is below:
<html lang=”en”>
<title>jQuery Button Sample1</title><link rel=”stylesheet” href=”../libraries/jqwidgetslibrary/jqwidgets/styles/jqx.base.css” type=”text/css” />
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/scripts/jquery-1.11.1.min.js”></script>
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/jqwidgets/jqxpanel.js”></script>
<script type=”text/javascript” src=”../libraries/jqwidgetslibrary/jqwidgets/jqxtree.js”></script>
</head><script type=”text/javascript”>
$(document).ready(
function ()
items:
{ label: “Item 4”,
items:
{ label: “Item 7” }
// Create jqxTree.
$(‘#jqxTree’).jqxTree({ source: source, height: ‘100px’, width: ‘300px’ });// Create Push Button.
$(“#jqxButton”).jqxButton({ width: ‘150’, height: ’25’});
// Subscribe to Click events.
$(“#jqxButton”).on(‘click’, function ()
alert(‘Button Clicked’);
$(‘#jqxTree’).jqxTree(‘ensureVisible’,8);
});</script>
<div style=’width: 150px;’ id=’jqxWidget’>
<div id=’jqxTree’></div>
<div> <input type=”button” value=”Button” id=’jqxButton’ /></div>
</div></div>
</html>If I can get this example to work – by selecting an item towards the end of the list, I think my misunderstanding will be resolved.
Many thanks,
Alastair
I have managed to resolve my own misunderstanding of how the tree ensureVisible method works.
I found a comment on this topic in a post in 2016. I copy the important text, as follows:
– … you need to get all of the elements of the jqxTree. You can do that using the getItems method from the jqxTree API.
– Iterate through them and check if the value is present.
– If it is, get the a reference to the element and using selectItem select that element. Every item that is returned from the getItems method, contains properties like “label” and “element”. “label” represents the actual text of the- of the current item(this will be compared to “CategoryINT” value that you get from the jqxGrid). “element” represents a reference to the
- tag.
Alastair
Thanks for the update!
