jQuery UI Widgets › Forums › General Discussions › How can I enforce a max content length in jqxEditor in Angular while still allow
This topic contains 1 reply, has 2 voices, and was last updated by admin 4 days, 7 hours ago.
April 24, 2026 at 10:39 am How can I enforce a max content length in jqxEditor in Angular while still allow #136617
Hi everyone, I am working on a SaaS settings panel with Editor.
I am currently trying to solve this: How can I enforce a max content length in jqxEditor in Angular while still allowing normal paste and undo behavior?
So far, I already checked the docs and basic examples, but the component updates only after a manual refresh.
What would be the cleanest way to implement this?
May 5, 2026 at 9:45 am How can I enforce a max content length in jqxEditor in Angular while still allow #136629Hi vitorio,
You can try this:
private maxLength = 500; private debounceTimer: any; onEditorChange(): void { clearTimeout(this.debounceTimer); this.debounceTimer = setTimeout(() => { const html = this.editor.val(); // jqxEditor HTML content const text = this.stripHtml(html); if (text.length <= this.maxLength) return; const trimmedHtml = this.trimHtmlToMaxLength(html, this.maxLength); // update editor safely (avoids continuous re-trigger loops) this.editor.val(trimmedHtml); }, 100); } // Removes HTML tags for accurate length checking private stripHtml(html: string): string { const div = document.createElement('div'); div.innerHTML = html; return (div.textContent || div.innerText || '').trim(); } // Simple safe fallback: trims by text length (keeps UX stable) private trimHtmlToMaxLength(html: string, max: number): string { const div = document.createElement('div'); div.innerHTML = html; let count = 0; const result = document.createElement('div'); const walk = (node: ChildNode, parent: HTMLElement) => { if (count >= max) return; if (node.nodeType === Node.TEXT_NODE) { const text = node.textContent || ''; const remaining = max - count; parent.appendChild( document.createTextNode(text.slice(0, remaining)) ); count += text.length; } else if (node.nodeType === Node.ELEMENT_NODE) { const el = node as HTMLElement; const clone = document.createElement(el.tagName); parent.appendChild(clone); Array.from(el.childNodes).forEach(child => { walk(child, clone); }); } }; Array.from(div.childNodes).forEach(node => { walk(node, result); }); return result.innerHTML; }This approach keeps:
undo/redo intact
paste behavior natural
no constant editor flicker
consistent max-length enforcement across input typesRegards,
Peter -
