jQuery UI Widgets Forums Grid Grid column : Delete icon at header level and checkboxes at row level ???
This topic contains 6 replies, has 2 voices, and was last updated by  mallepaddi 12 years, 10 months ago.
  • mallepaddi
    Hi
    I would like to show “Delete” icon like header level and displaying check boxes at row level, would it be possible of doing this ?
    Hello mallepaddi,
    Yes, it is possible by using the renderer callback function which can modify a column’s header. Here is an example, based on the demo CheckBox Column:
    var data = generatedata(200, true);
    localdata: data,
    datafields:
    datatype: "array"
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    { text: 'First Name', editable: false, datafield: 'firstname', width: 100 },
    { text: 'Last Name', editable: false, datafield: 'lastname', width: 100 },
    { text: 'Product', editable: false, datafield: 'productname', width: 180 },
    { text: 'Available', datafield: 'available', threestatecheckbox: true, columntype: 'checkbox', width: 70, renderer: function () {
    return '<button id="delete">Delete</button>';
    { text: 'Quantity', editable: false, datafield: 'quantity', width: 80, cellsalign: 'right' },
    { text: 'Unit Price', editable: false, datafield: 'price', width: 90, cellsalign: 'right', cellsformat: 'c2' },
    { text: 'Total', editable: false, datafield: 'total', width: 100, cellsalign: 'right', cellsformat: 'c2' }
    <div id="jqxgrid">
    Instead of a button, renderer may return an image:
    return '<img src="delete.png" />';
    mallepaddi
    perfect,
    I have written like …
    { text: ”, datafield: ‘incart’, threestatecheckbox: false, columntype: ‘checkbox’, width: ‘5%’, renderer: function () {
    return ““;
    Image appearing at header level followed by ‘check boxes”
    but following event is not firing to delete selected items …
    $(“#delete”).click(function(e){ alert(‘clecked’); }
    Please help.
    mallepaddi
    Problem solved … with combination of “renderer” and “rendered”.
    Hi mallepaddi,
    Here is a modification of the example that shows how to bind to the button’s onclick event:
    localdata: data,
    datafields:
    datatype: "array"
    width: 670,
    return '<button id="delete" onclick="clickFunction()">Delete</button>';
    <div id="jqxgrid">
    var clickFunction = function () {
    alert("clicked");
    mallepaddi
    Hi
    I’ve managed to click image created at header level for deleting items selected in shopping cart.
    { text: ”, datafield: ‘incart’, threestatecheckbox: false, columntype: ‘checkbox’, width: 25,
    return “
    rendered: function (columnHeaderElement) {
    $(columnHeaderElement).on(‘click’, function (event) {
    deleteRowsFromCart(event);
    { text: ‘Description’, datafield: ‘description’, editable: false,width: 190},
    { text: ‘Price’, datafield: ‘price’, width: 70, editable: false,cellsalign: ‘right’, align: ‘right’},
    { text: ‘Qty’, datafield: ‘qty’, width: 60, editable: false, cellsalign: ‘right’, align: ‘right’},
    { text: ‘UoM’, datafield: ‘uom’, editable: false}
    but i can click “Delete” image at header if having following code ..
    var cartdataAdapter = new $.jqx.dataAdapter(cartsource, {
    $(“#columntable”+”jqxgrid1”).find(“[role=’columnheader’]”).eq(0).find(“div”).css(‘width’,’25’).css(‘margin-left’,’0px’);
    loadError: function (xhr, status, error) { alert(‘Data load error !!!’);}
    But “Delete” icon can’t be clicked if i have deleted one item from shopping cart , i guess it could be because of positioning / alignment of code generating by grid header.
    How to solve this issue ..
    mallepaddi
    Hi
    Work around …
    var adjustDeleteIconPosition = function(event){
    calling above method in deleteRowsFromShoppingCart() method. Position of Deleting icon is consistent now ..
    Thanks.
