jQuery UI Widgets › Forums › Lists › ListBox › double click on listBox
Tagged: dblclick, double-click, item, jqxListBox, ListBox, select, selectItem
This topic contains 1 reply, has 2 voices, and was last updated by Dimitar 9 years ago.
Authordouble click on listBox Posts
is there a way to implement double click to select item in listBox ?
Hello jahnvi25,
Here is how to implement listbox item selection on double click:
<!DOCTYPE html> <html lang="en"> <head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.10.2.min.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> </head> <body> <div id='content'> <script type="text/javascript"> $(document).ready(function () { var source = [ "Affogato", "Americano", "Bicerin", "Breve", "Café Bombón", "Café au lait", "Caffé Corretto", "Café Crema", "Caffé Latte", "Caffé macchiato", "Café mélange", "Coffee milk", "Cafe mocha", "Cappuccino", "Carajillo", "Cortado", "Cuban espresso", "Espresso", "Eiskaffee", "The Flat White", "Frappuccino", "Galao", "Greek frappé coffee", "Iced Coffee", "Indian filter coffee", "Instant coffee", "Irish coffee", "Liqueur coffee" ]; // Create a jqxListBox $("#jqxWidget").jqxListBox({ selectedIndex: 3, source: source, width: 200, height: 250, enableSelection: false }); $("#jqxWidget .jqx-listitem-state-normal").dblclick(function (event) { var item = $(event.target).text(); $("#jqxWidget").jqxListBox("selectItem", item); }); }); </script> <div id='jqxWidget'> </div> </div> </body> </html>
