jQuery UI Widgets Forums Grid Delete button not firing
This topic contains 3 replies, has 2 voices, and was last updated by  mr_putersmit 13 years, 11 months ago.
  • Delete button not firing #6301
    mr_putersmit
    Hello
    I am having a terrible time trying to get the delete function to work. I studied the CRUD example and thought I had it, but the code I have doesn’t fire at all. Also, when I click the button there is nothing coming back in firebug, errors of code. I would be grateful if someone could check my code and point out my errors. Thanks
    index.php
    { name: 'id', type: 'number' },
    { name: 'slot'},
    { name: 'service'},
    { name: 'activity'},
    { name: 'department'},
    { name: 'company'},
    { name: 'user'},
    { name: 'item'},
    { name: 'filebox'},
    { name: 'destroyedby'},
    { name: 'destroyedbydate', type: 'date', format: 'yyyy-MM-dd HH:mm:ss'},
    { name: 'destdate', type: 'date', format: 'yyyy-MM-dd HH:mm:ss'},
    { name: 'date', type: 'date', format: 'yyyy-MM-dd HH:mm:ss'},
    { name: 'type'},
    { name: 'notes'},
    { name: 'new'},
    url: 'data.php',
    deleterow: function (rowid) {
    // synchronize with the server - send delete command
    var data = "delete=true&id=" + rowid;
    dataType: 'json',
    url: 'data.php',
    data: data,
    // delete command is executed.
    alert('success');
    $("#deleterowbutton").jqxButton({ theme: 'classic' });
    $("#jqxgrid").jqxGrid(
    source: source,
    theme: 'classic',
    altrows: true,
    pagesizeoptions: ['10', '20', '30', '40'],
    width: 800,
    rowdetails: true,
    { text: 'id', datafield: 'id', width: 40},
    { text: 'Service', datafield: 'service', width: 100},
    { text: 'Activity', datafield: 'activity', width: 100 },
    { text: 'Department', datafield: 'department', width: 90 },
    { text: 'Company', datafield: 'company', width: 90 },
    { text: 'User', datafield: 'user', width: 150},
    { text: 'Item', datafield: 'item', width: 100 },
    { text: 'Filebox', datafield: 'filebox', width: 180 },
    { text: 'Destroyed By', datafield: 'destroyedby', width: 120 },
    { text: 'Destroyed By Date', datafield: 'destroyedby_date', columntype: 'date', width: 180, cellsformat: "dd/MM/yyyy hh:mm:ss"},
    { text: 'Destroyed Date', datafield: 'destdate', columntype: 'date', width: 180, cellsformat: "dd/MM/yyyy hh:mm:ss" },
    { text: 'Date', datafield: 'date', columntype: 'date', width: 180, cellsformat: "dd/MM/yyyy hh:mm:ss" },
    { text: 'Quantity', datafield: 'quantity', width: 70 },
    { text: 'Type', datafield: 'type', width: 70 },
    }); // delete row.
    $("#deleterowbutton").bind('click', function () {
    var selectedrowindex = $("#jqxgrid").jqxGrid('getselectedrowindex');
    var id = $("#jqxgrid").jqxGrid('getrowid', selectedrowindex);
    $("#jqxgrid").jqxGrid('deleterow', id);alert("click");
    data.php
    $row['id'],
    'slot' => $row['slot'],
    'service' => $row['service'],
    'activity' => $row['activity'],
    'department' => $row['department'],
    'company' => $row['company'],
    'user' => $row['user'],
    'item' => $row['item'],
    'filebox' => $row['filebox'],
    'destroyedby' => $row['destroyedby'],
    'destroyedbydate' => $row['destroyedby_date'],
    'destdate' => $row['destroydate'],
    'date' => $row['date'],
    'quantity' => $row['quantity'],
    'type' => $row['type'],
    'notes' => $row['notes'],
    'new' => $row['new']
    echo json_encode($act);
    Delete button not firing #6305
    mr_putersmit
    Can anyone point me in the right direction to solve this problem? Many thanks
    Delete button not firing #6308
    Hi mr_putersmit,
    I think that this code:
    is outside of your script because you have
    Delete button not firing #6312
    mr_putersmit
    Thank you Peter
