jQuery UI Widgets Forums Chart Add "0" to hour and minutes
This topic contains 2 replies, has 2 voices, and was last updated by  brogen 9 years ago.
  • Add "0" to hour and minutes #76331
    brogen
    Hi all,
    Example here
    I’m trying to “change” my value on xAxis.
    Now : 17 Sep 0:0
    I want : 17 sep 00:00
    I have another question, less important.
    Is it possible to have “17 sep 00:00” on xAxix and : “17/9/2015 00:00” on Crossair ?
    Any easy advice ?
    Add "0" to hour and minutes #76337
    Vladimir
    Hello brogen,
    Yes it is possible to do both things.
    The crosshair format is specified in the seriesGroup toolTipFormatFunction property of the series.
    And the xAxis labels are specified in the xAxis: { labels: {formatFunction: myformatFunction(data) {//apply your formatting here and return a string} } }
    Having this said, regarding your first question you could use format like the following:
    formatFunction(date){
        var months = ['Jan', 'Feb', 'Mar', 'Apr', 'May', 'Jun', 'Jul', 'Aug', 'Sep', 'Oct', 'Nov', 'Dec'];
        return date.getDate() + ' ' + months[date.getMonth()] + ' ' + ("0" + date.getHours()).slice(-2) + ':' +  ("0" + date.getMinutes()).slice(-2);
    Vladimir
    Add "0" to hour and minutes #76344
    brogen
    YES ! I was looking for that for arround 4 days now. But i wanted ask again…
    It’s working.
    I just added a comma ^^
    Thanks for all, again :).
