jQuery UI Widgets Forums Grid Sort filter not applied when changing source ?
This topic contains 2 replies, has 2 voices, and was last updated by  punkrack 11 years, 8 months ago.
  • punkrack
    Hi !
    I don’t know if this is done correctly, but here it is :
    I initialize a grid on document.ready. I click a button, and I change $(“#jqxgrid”).jqxGrid({ source: dataadapter});
    I then change the columns order. The source.sortcolumn is not applied. In this example, source stays the same except for sorting, but in real world, it will change a lot.
    Working example here :
    http://colligedev.ccdmd.qc.ca/test-jqxwidgets/test.php
    Just press change, you will see grid change but sorting on “Modele” is not applied.
    Here is basic code :
    sortcolumn: 'titre_fiche',
    sortdirection: 'asc',
    { name: 'chk_box', type: 'string'},
    { name: 'titre_fiche', type: 'string'},
    { name: 'titre_modele', type: 'string' },
    { name: 'type_acces', type: 'string' },
    { name: 'date_modification', type: 'date' },
    { name: 'suivi', type: 'string' }
    cache: false,
    url: 'abc.php',
    filter: function()
    sort: function()
    root: 'Rows',
    if (data != null)
    loadError: function(xhr, status, error)
    alert(error);
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid( {
    width: '100%',
    source: dataadapter,
    theme: jqw_theme,
    selectionmode: 'singlerow',
    autosavestate: false,
    autoloadstate: false,
    virtualmode: true,
    showdefaultloadelement: false,
    pagesizeoptions: jqw_pagesizeoptions,
    //pagesize: 20, /*Lignes visibles par défaut. Ex: 20.*/
    rendergridrows: function(obj)
    return obj.data;
    ready: function()
    { text: '', datafield: 'chk_box', sortable: false, filterable: false, editable: false, width: '5%',
    renderer: function () {
    return '<div id="jqxgrid_chkbox_all"></div>';
    { text: 'TITRE', datafield: 'titre_fiche', width: '45%' },
    { text: 'MODÈLE', datafield: 'titre_modele', width: '15%' },
    { text: 'ACCÈS', datafield: 'type_acces', width: '10%' },
    { text: 'DATE MODIFICATION', datafield: 'date_modification', filtertype: 'date', editable: false, cellsalign: 'left', cellsformat: 'd MMMM yyyy, HH:mm', width: '20%' },
    { text: '', datafield: 'suivi', sortable: true, filterable: false, editable: false, width: '5%',
    return '<div id="jqxgrid_suivi_all"></div>';
    function change() {
    sortcolumn: 'titre_modele',
    cache: false,
    url: 'abc.php',
    filter: function()
    sort: function()
    root: 'Rows',
    if (data != null)
    alert(error);
    $("#jqxgrid").jqxGrid({ source: dataadapter});
    I tried
    $(“#jqxgrid”).jqxGrid(‘updatebounddata’);
    $(“#jqxgrid”).jqxGrid(‘render’);
    it does not work.
    Also, it I press change, save the state and try to load the state, it will not save the “changed” state.
    Thanks for checking this out.
    Hi punkrack,
    When you change the Grid’s Data Source, any previous sorts, filters, etc. will be removed by design.
    punkrack
    ok thanks for answering my question !
