jQuery UI Widgets › Forums › Grid › Grid custom filtering with remote json not working
This topic contains 1 reply, has 2 voices, and was last updated by Peter Stoev 11 years, 10 months ago.
Hi Support,
I have this datasource and grid:
var source = {
datatype: ‘json’,
{“name”:”id”,”type”:”number”},
{“name”:”gyszam”,”type”:”string”},
{“name”:”nev”,”type”:”string”},
{“name”:”leltarid”,”type”:”string”},
{“name”:”bvig”,”type”:”string”}
url: ‘/Home/GetEszkoz’,
sortcolumn: ‘gyszam’,
sortdirection: ‘asc’,
pagesize: 10,
filter: function () {
$(‘#jqxgrid’).jqxGrid(‘updatebounddata’, ‘filter’);
sort: function () {
$(‘#jqxgrid’).jqxGrid(‘updatebounddata’, ‘sort’);
root: ‘Rows’,
source.totalrecords = data.TotalRows;
};var dataadapter = new $.jqx.dataAdapter(source);
$(‘#jqxgrid’).jqxGrid({
width: ‘100%’,
theme: ‘darkblue’,
selectionmode: ‘singlerow’,
source: dataadapter,
showtoolbar: true,
showfilterrow: true,
pagesizeoptions: [’10’, ’25’, ’50’],
virtualmode: true,
rendergridrows: function () {
return dataadapter.records;
{“text”:”id”,”datafield”:”id”,”width”:0,”hidden”:true},
{“text”:”Gyári szám”,”datafield”:”gyszam”,”width”:150,”hidden”:false},
{“text”:”Tipus”,”datafield”:”nev”,”width”:150,”hidden”:false},
{“text”:”Leltár kód”,”datafield”:”leltarid”,”width”:90,”hidden”:false},
{“text”:”BVIG”,”datafield”:”bvig”,”width”:120,”hidden”:false}
});This is working remotely filter, page, sort on server side. It is Ok. After the grid was initaialized, loaded with datas, if I would like to use a filter programmatically like this (for example with a button click):
$(“#jqxgrid”).jqxGrid(‘clearfilters’);
var filteroperator = 1; // 1 – and, 0 – or
var filtervalue = event.args.row.gyszam;
var filter = filtergroup.createfilter(‘stringfilter’, filtervalue, ‘contains’);
filtergroup.addfilter(filteroperator, filter);
$(‘#jqxgrid’).jqxGrid(‘addfilter’, “gyszam”, filtergroup, true); //this line code is brokenI got this error message to console:
jqxGrid: The data is still loading. When the data binding is completed, the Grid raises the ‘bindingcomplete’ event. Call this function in the ‘bindingcomplete’ event handler.
Please advice,
Lajos
Hi Lajos,
The message says it clear: It is not possible to add/remove filters, do sort or change a Page while the Binding operation is not completed. When it is, the Grid will raise a “bindingcomplete” event and you will be able to add your custom filters.
